About two months ago I broke the socket that the headlight plugs into on the passenger side of my saab. I order the part from my saab dealer and just recieved it this morning. First of all HOLY SH*T is that thing hard to install. I thought it would take me about 5min to install. But no ... it requires complete disasembly of the headlight. Two hours and a lot of cursing later I finally got the darn thing rewired and installed and guess what? No headlight. But here is the oddity the highbeams work. Ok I thought must be the bulb I happened to have an extra and popped it in. Still no light. I then tested the bulb on the drivers side it worked fine but not on the passanger side. I am completely stumped why would eveything but the regular low beam headlight work??? I can't even begin to think of what could be the problem. Obviously not a fuse problem, Not a wiring problem since I just replaced it and the high beam works, and not a bulb problem. Any guesses!?
I have to say I have dropped nearly 2k into this car in the past two months and am beginning to seriously contemplate putting it out of its misery.
Believe me it has been done!
You say it is obviously not the fuse. The offside and nearside dipped headlights do have separate fuses. LH is number 6 fuse, and RH is number 7 fuse in the engine bay fusebox. Inspect, and try swapping the fuses around, and renew if necessary - 10 amps.
Then, of course, think about the relay (unlikely).
HTH
I forgot to thank you for your correct advice. I am a fool and did not know the headlights have seperate fuses in the engine bay. That was the problem. Gotta love 28 cent fixes! Thanks for the help.
