This morning I noticed on my drivers door the door lock and window switches were flashing on and off. The switches don't work so I can't unlock the doors or roll window down via drivers door.
Half way through my drive it stopped and everything worked well. I rolled down my window and of course then it started again.
Any suggestions on what this could be?
battery
Have you checked battery voltage, saabs dont like low battery voltage.
When driving it might be ok due to alternator giving required voltage.
Not running battery should be 12.6v+
Charging should be around 14v
Battery needs a load discharge check to make sure all ok, not just voltage check.
Check the battery
Yes, check the battery. You may be due for a new one.
Don't wait too long for this as these cars can have ECU and Software, or Electrical problems if the battery goes completely dead.
No I checked battery its perfect. It wasn't working while driving either. There has been a lot of rain lately maybe getting in and out of the car got something wet?
