1 - 7 of 7 Posts
I've noticed that when my car gets hot that there is significant loss of performance like the boost doesn't reach the normal pressure. I borrowed my buddies bluetooth obd2 transmitter and have been logging data to try and determine if there was a measurable problem. I have noticed now that the normal 14.7lbs of boost i was getting earlier in the year when i had no problems now barely reaches 13 when it is performing well but other times only reaches 10-10.5.
What would cause this when the car gets hot? (this is usually when it happens but not always)
Heat soak wouldn't explain 5psi of boost loss though especially with an charge air cooler.......
Did you try pulling the F2 fuse to reset the ECU. These cars learn how you drive and adjust to get better fuel economy. After a month mine gets a little sluggish so I rest it with the f2 fuse and its like night and day. If thats not it maybe some else will chime in here..
I haven't heard of this yet. ill try doing this. how long do i need to leave it out?
1 - 7 of 7 Posts
