Hi,
I write this new thread because I'm desperate with my Anti-lock system on my 900 Turbo S 92.
I search on saab net, saab link, saab central ... etc I didn't find a good answer.
The symptoms
- Anti-Lock bulb is lighting most of the time
What I have done
- Read fault code : In order 4444, 1142, 1241, 1111 or depends of the ECU :evil:
- Check all component : all resistance of the inlet and outlet valves (4 ans 7 ohms), sensors (1150ohms) everything is good
- Hear starting and stopping pressure pump
- Change ecu with 2 used
- test the accumulator : 5 pumps
- cleaned sensors one year ago.
I noticed :
when i start the car, sometime the light came back only when I push the brake pedal for the first time.
When I driving, the light switched off only 2-3% of the driving time and came back only on bump.
I'm thing a wire problem or a bad ecu... but i try 3... used.
Do you have an idea ?
Thank in advance
Kévin
The symptoms
What I have done
I noticed :
Thank in advance
Kévin
