Geez, this car is a pain in the butt... I hate the fact that I love it so much.
Got the subs installed correctly (finally), tapping the signal off the front speakers, to a LOC (http://www.tsunamionline.com/product.php?id=454), then into my amp (http://cgi.ebay.com/ebaymotors/SONY-480-WATT-AMPLIFIER-Retails-199-95-BRAND-NEW_W0QQcmdZViewItemQQcategoryZ38638QQihZ002QQitemZ120093559927QQrdZ1QQsspagenameZWD1V).
Well, i had the same amp and sub in my jetta and it sounded great. I did have an aftermarket explode headunit though, with a sub output and sub controls built into the headunit. It also had LPF and HPF.
1st question. When the stereo is turned up loud, my lights dim. Now I know that means i need to add a capacitor, but I can't believe that my car can't handle this small load the amp is drawing. I have had 2 thousand watt amps hooked up, and that was the only time I have ever had any light dimming. This is probably my 7th or 8th stereo setup i have had, and find it "odd" that i need a cap on such a small stereo.
2nd question. When I was tuning my system, all off a sudden the entire channel went out and turned off. The only speakers that were working were the rear deck speakers. Every other one was off, but the amp still had power. Turned the car off, restarted, and everything was fine.
3rd question
I was cycling through the various inputs (aux, radio, CD) and the radio started reciving a signal for a sec, then turning off. Right before it turned on, it made a beep, turned on for a sec or two, turned off for a sec or two, repeat. Anyone know why? Turned the car off and then on, and everything was back to normal.
4th question
If i am working on my car, is there any way i can get the door lights to turn off when the doors are open? I don't like the idea of them draining my battery for no reason.
Thanks for the help!
3rd question
4th question
