Hi,
I recently had some work done on my Saab 9000 cd (1996) as the indicators weren't working. This happened to just be the relay which was loose and has since been fixed. However, ever since the electrician left, the stereo system (after market) and analogue clock no longer work. They worked fine prior to the electrician doing what he did, so I was wondering if it could possibly be a relay? The fuse (#19) was still working and did not look burnt out.
Fuse 27 looks to be intact as well. I forgot to mention that the battery was also just replaced if that would make a difference?
Replacing the battery should not cause this. Try pulling the head unit and measuring voltage on the red and yellow wires with the key on. Maybe the stereo was just unplugged.
If you paid for this work to be done, I'd take the car back there and tell them to make it right.
