Hi,
I recently sourced the AS3 upgrade for my 2002 9-3 Aero from a car of the same age thinking it would be a simple install. After fitting the door speakers and plugging in the amp to the existing wiring the stereo was switched on and was sounding good for a few seconds when the amp stopped working, I removed the amp and checked the fuse which was ok. An electronics guru and friend of mine had a look and discovered there was a damaged track on the PCB which he repaired ,the amp was then refitted switched on and once again was sounding good, for a few seconds,when this time the fuse went.
Has anyone got any ideas about this as it is becomming a right pain in the a**e.
Kenny.
Kenny.
