I just tightend the nut that holds the steering wheel adjustment lever and it made a world of difference in the car. This is a small 10mm nut on the base of the lever that allows the steering wheel to travel in and out. Steering wheel shake is almost gone and the the clunking noises going over bumps have lessened. This is definitely something to check if you have steering shimmy or suspension noises. The steering linkage did not seem to be loose and I was very suprised at the results. There was a tiny bit of vertical play that led me to investigate.
1997 900SE 130k miles
