Not with the driver side airbag you don't.UK9K said:You only need a small flat blade screw driver to take the SAAB centre badge off and a 22mm socket with extension. Then just wiggle the wheel either side and it'll just pull off nice and easy. Don't put your face too close to it as you pull though, you'll end up caving in your face!! Yup, I've done that a couple of times on previous cars.
Yes, and it's dead easy - you just need to undo two bolts on the sides of the wheel, pull the airbag module out (carefully) and disconnect the leeds. Note that the bolts are "hidden" under the plastic caps so you need to remove them first. Also, make sure that the battery is disconnected for at least 10-15 minutes before unplugging the airbag.UK9K said:oic, ok. So the airbag is removable from the main body of the steering wheel prior to removing the main body then?
