much has been written about the crappy cd players in our cars.
I've changed mine. I was lucky to find a "new old stock" unit on ebay.
I changed mine cause of the skipping issue everyone else has. Also, folks complain about the steering wheel controls and I've read all kinds of opinions as to what causes that one.
I can tell you I used some CAL LUBE on my steering wheel controls switches and have not had a problem since. CAL LUBE is made for plastic switches and will not destroy the inside/plastics of the switch.
So far it's been a couple of months since I used the stuff and no problems. Some here Poo Poo spraying the switches and insist it's something more elaborate. I say "keep it simple" and since I'm an electronics hobbyist, I had the stuff on hand. I think it cost about $10 for a small spray can that will last for years. I first used it on my drivers window switch which was not working most of the times. Since I've sprayed that, NO PROBLEMS for over 5 months.
I hope my advice will help you out.
The product is called CaiLube MCL CAIG laboratories
www.caig.com
CaiLube MCL
Name change in 2006 from CaiLube MCL to DeoxIT® FaderLube, part numbers changed.
NOTE: (Name change in 2006: From CaiLube MCL to DeoxIT FaderLube, part numbers remain the same)
To purchase, go to DeoxIT ® FaderLube Products.
Our DeoxIT Brand is growing worldwide!
The new product names will be as follows:
• ProGold will change to
DeoxIT®
GOLD
• PreservIT will change to
DeoxIT®
SHIELD
• CaiLube L260 Greases will change to
DeoxIT®
L260 Greases
• CaiLube MCL will change to
DeoxIT®
FaderLube.
• CaiLube MCL Greases will change to
DeoxIT®
Fader Grease.
