I dont like the look of the steering wheel and airbag in pre 95 9k's. so the question is, can you swap an air bag and steering wheel from a 1995 9k into a 94 9k and everything work right?
The steering wheel from the 1995 will fit on the splined end of the steering column shaft on the 1994.
The biggest concern would be to make sure the connector for the air bag on the clockspring on the 1994 will work with the airbag from the 1995
If you swap both the steering wheel and the airbag it should work. The clock spring is the same.
