HI, JERRY ORREN here, I have a 1995 Saab 900 SE Conv. sometimes will start, sometimes not. dash lights very dim-wont start; dash lites normal -will start. also window motors may or may not work. I think this is a ignition switch problem.
So change it and stop whining. We are here to help.YES, I DID ALL OF THOSE. I think the problem is in the ignition switch
your initial answer was kinda rude; thanks for softening it.So change it and stop whining. We are here to help.
Auto is even easier imo, you don;t have to undo any linkage, once you remove the console and the 4 bolts holding the shifter in place you should be able to turn it sideways or upside down to access the switch module.This is for the manual tranny. If you have automatic, it might vary. Someone else will have to advise on that and give you any shortcuts./
If only they had a middle finger emoticon so we could be sure...
