Hi,
Short version: My starter is tired and needs a rebuild. Can I 'buy a clue' as to if I can remove it from under the hood or if I want to go to a friend's garage with a lift?!
Longer version: It grinds over slowly and for too long before it starts. It failed to start once this week, and I applied 12 volts directly to a solenoid terminal to start the car.
I plan to disassemble and clean the starter & solenoid, check the brushes, etc. IF I can remove it! (234k miles, have not touched the starter since we bought the car at 120k miles...)
(Dennis' writeup here is very good:
http://www.saabcentral.com/techhelp/c900/900_starter_diagnostics.php
Are there any significant differences between the 900 and 9000?)
I have a good local autoelectric rebuilding shop, if I get in trouble, but I am thinking that cleaning and replacing the brushes is $10 vs $120...
Any special tools? Torx drives, etc.?
Are the starter bolts accessible from the front / timing belt end or the bell housing / back end.
Thanks for any 'clues' / Saab 9000 secrets anyone can offer!
Regards,
'C' in NH, USA
If you have an air impact. It take 30 seconds to remove the two nuts on the starter. One 17 mm socket and another 15 mm socket I believe. Slip the air impact behind the engine in front of the firwall standing on the passenger side.
Thanks for the tip.
I'm being brave and running one more errand today before starting the job. (I did pickup a 'tested used starter' for $35 from a local salvage yard. Hopefully I wont be installing it n the side of the road!)
Feeling lucky, but trying to remember a time in my life when 'getting lucky' meant something different...
Do disconnect the battery first before you attempt it. Next remove the two wires on the starter. The yellow wire to the solenoid need a 10 mm socket. The thick battery cable 13 mm socket. Good luck.
