Stutter a lot and occasionally died on me at a red light or stop sign. I basically drive like a standard one foot on the gas and the other on brakes just in caseCould be the crank position sensor. How does it stall: does the engine die away, or does it just instantly cut out, or does it stutter and occasionally fire?
Changed the plugs last summer but I’ll check into trying a new cassette and or the cpsHmm, I don't know what might be causing that. Maybe a failing ignition cassette. Is it original/OEM (labelled SEM) and are the spark plugs the correct ones and in good condition?
Is the Check Engine light on? Has the car been scanned for engine codes?
Replace CPS ASAP.
Replace bypass valve.
Thanks so much mimmi I kinda thought about the CPS but will replace the bypass valve tooReplace CPS ASAP.
