Hi,
What should I be boosting on my 02 93 HOT (M) with stage 3 ECU?
Jules
Jules
If you have the equipment to look into airmass (OBD logger) look into that instead of boost. I have airmass plots from two stage III 93 HOT cars if you want to compare.Jules93Conv said:Hi,
Jules
I am boosting the same thing with the same setup that ricot83 has and I am doing it on a 2000 9-3 SE HOT Automatic with the following mods.ricot83 said:dont know if this will help but.. i only run i think 7-9psi.. with stage three hardware and stock software.... stock boost was about the same iirc.... so u r pretty good if u r around 16psi with your lower octane gasoline.
If you really want to know about that PM me and I will give you the long sorted messed up story up to now!! But it's not over yet and hopefully it will happen in the next 2 weeks before Battle of the Imports at the end of this month.ricot83 said:sos steve still no ECU?????
