1 - 7 of 7 Posts
Ok, I searched here and I see different results, some say its under the center console, and I have seen where its said to be behind the front ash tray.
So where is it exactly, under the parking brake console/plastic? Right?
Also, does anybody know exact part model for 98' 900SE? I found few different ones such as : 46 19 680 , 44 33 645, 52 66 564, or I just have t open and see what's mine and buy the same match?
Thx,I guess its at least somwwhere there. Does anybody know where it is exactly?
I might just have to open that section and look for it :)
If you pull the console up, you can't miss it. It's the only electronic module under there aside from the antenna for the security system. The antenna is in a plastic case about 1x4" in the very rear of the console. The SRS module is a metal case about 3x3" and bolted to the floor.
Discussion Starter #6
Yea you are right Bob. I just pulled it up (not all the way) just to see the right part number, and it is 46 19 680, so I ordered one like that and will be changing it soon in hopes my SRS light goes off.
Here are some pictures, not that great, but I haven't seen any here on forum so it might help somebody. (The orange thing is the connector)
1 - 7 of 7 Posts
