Hi all,
I'm trying to wrap my head around the spring codes (both front and rear) for the 9-5. I can find lots of posts of the sort "if you have this model, use this spring," but I can't find any threads that actually discuss the physical differences between the spring codes. Has anyone found any info regarding how the codes correspond to spring rate and ride height? Are all the different springs interchangeable between the various 9-5 models and trims, or are there other differences in other suspension components that dictate which spring(s) can and cannot be used?
For me, specifically, I need to replace the rear springs on my 2003 Aero wagon. I want to swap out the completely shot OEM "sport" springs with whatever will give me the stiffest spring rate with the tallest ride height. Yes, I want to raise my Aero rather than lower it. Apologies to the purists!
Thanks!
Thanks!
