So I'm trying to plan out my build for the the spring...So far it consists of forged rods and pistons, ARP studs and headbolts, cometic gasket, but my main focus is to see if I can squeeze a top mounted Gt3076r in there...
I'm trying to see every option for top mounting before I look at a bottom mount, which HAS been done on this engine, BUT...I'd have to v-band my exhaust and most likely re-do the whole thing. If It's top mounted, I can get the Cosworth style turbine housing from ATP Turbo/Garrett that uses the same bolt pattern as my 3" downpipe...which would be awesome.
Couple questions that can make/break the deal:
I will need a custom exhaust manifold with a T3 flange, but how crucial is a tubular manifold with this size turbo, over a log type like our stock one? I've seen some NG guys with the log type, but trying to make a top mount with a tubular manifold will either be a mess of pipes, or impossible to fit with the space I have. I feel like the extra volume of pipe would cause it to spool later, but the air flows easier. Plus these are super expensive to have made.
Log types are shorter and should spool a little quicker, and way cheaper. But "uglier", (which frankly I don't give a SH*T what it looks like, as long as it does it's job), and probably a little more restriction than a tubular one...
My goal is to have it very tame on the street from low rpm up to around 3k or so, but I don't want to have to wait until 4k for when it's just starting to spool. Basically just so there isn't as much of a torque spike down low. I'm also planning to use this in conjunction with e-85 at some points, but not all the time.
Any thoughts or opinions?
