hi SC
i want to upgrade my 00 lpt suspension with a 2004 aero at my local junk yard my plan so far is to remove the 3 bolts and nuts from the balljoint and the three bolts from the strut tower brake lines tie rod ends and swaybar links and axle from the transmission of course then remove the spindle with everything. i know for sure that the only part that i can reuse from my car is the swaybar links and the lower control arm my questions are
will the strut mount fit in the same position?
will the 2004 axles fit my manual trans?
are the brake lines the same?
and will the 02-09 tie rod ends fit my steering rack?
any help pointers and suggestions just keep in mind that money is an issue as i just bought a clutch kit and poly bushing for the whole front end, since i'm dropping the subframe i want to do the brakes as well and put the cobalt ss brembos in the future if i can find one.
