I took my 1990 SPG in for a front end alignment. I explained to the guy that I'd just replaced all 4 ball joints and upper control arm bushings so I wanted a complete camber, caster, toe-in alignment. No problem he said. I handed 4 extra shims I'd picked up at the salvage yard while scavenging 2 upper control arm bearing brackets.
The technician worked at least 2.5 hrs with my Saab on quite an impressive, computerized alignment rack. I thought, "Wow, I'm getting my $69.95 worth." But finally the cust. ser. rep. says, "He's got it the best he can get it right now, but he needs more shims and we don't have any like it needs. It's 100% better than it was, and good enough to drive until we can get more shims, but you'll need to bring it back." He noted the same on my invoice and mentioned their 6 month guarantee. I offered to track down the shims.
Well, the car does drive and handle quite well. In fact, if the rep had told me that the job was finished I would have had no reason to doubt him. However, after driving for a while I noticed a noise reminiscent of the bad ball joints I'd just replaced. I popped the hood to check and 3 of the 4 bolts on the passenger side upper control arm brackets were loose. One was quite loose; the other two just needed snugging up. Also, I found two shims laying down in the frame member (or whatever you call it on a Saab) directly under the RH control arm bracket nearest the firewall. So what's with "not enough shims?"
This is a fairly large, professional, and reputable local chain tire store, as evidenced by their honesty in telling me they weren't satisfied with the job and wanted me to bring the car back. Like I said before, based on the way it drives, I can't tell that the camber/caster is not perfect. And I know that many alignment shops just do the toe-in and it never occurs to the customer 5,000 miles later when his tires wear uneven that it was a crappy alignment that was done. So, this shops honesty in that regard instills at least some confidence. But, I'm really concerned now about the competence of the tech who worked on my SPG. Was he just having a bad day? Personal problems? It was late on Friday; maybe a hot date?
Here's my question: When I go back, how will I know whether or not I'm getting a good alignment? I'm not talking about the obvious things like handling, drifting, centering, etc. I mean, is there any way to know? Any advice in handling this situation would be appreciated. Especially any wisdom from that sage of Saab knowledge, Jim Mesthene.
Sc
Sc
