yip, take off the DI, remove plugs, insert into DI - stand back & switch on
(advice unplugging your injectors)
otherwise listen when you shut off after cranking, you should hear the plug self clean indicating a spark
Ok Norman but do I need to ground the plug body to ground to see a spark or am I listing for the cleaning that you mentioned.
Steve
Yes do rest the plug ends on the Chead to ground them
But do unplug the injectors or you will very quickly have a lot of fuel vapour going about
But first off listen for the self clean when you switch off, best your under the bonnet & a someone else spins the engine & shuts off
