So I'm replacing my spark plugs and I have been told its really important to get the right ones.
The Bentley says NGK BCP7EV or NGK BCP7ES
The Saabsite.com only has BCPR7ES11 (I'm assuming they are NGK's) or BCP6ES
Partsforsaabs.com has NGK BCP7EVX for 1984-1993 Turbo 16 Valves but they have NGK BCP7ES's for the 8v Turbo but mine is a 16v but that would agree with the Bently
I just don't want to get the wrong spark plugs, has anyone used the saabsite or parts for saabs one in their 16v turbos or know which work . . .any advise would be greatly appreciated.
IF it's an '87 900 Turbo, then it's 16 valve and BCP7ES is the right one. The 8 valve will use BP7ES (no C in it). Also, any NGK plug with -11 (two numbers) at the end is for a "wide-gap" installation, and the C900 is certainly NOT a wide-gap use, so the BCP7ES-11 is wrong for our cars. BCP7ES IS the right one. Don't get anything else. NGK BCP7ES. The gap is .024" - .028". Vern
Any website that I can get these from because thesaabsite and partsforsaab have slight deviations from what it should be
And yes its an 87
