1 - 18 of 18 Posts
· Registered
I searched and found a lot of discussions of plug gaps and so forth. A lot of information or misinformation as to the type of plugs, what type (they say NOT to use iridium)....
So my question is, what is the plug to run on a stage 3 2.0T (2008) and at what gap?
Brand and model number will be greatly appreciated.
Thanks
96mn12
· Registered
What plugs are you using right now? If you get misfire with stock plugs, try narrowing the gap. If that doesn't work, you might need to run iridiums. I don't understand why people have been complaining about the plugs breaking apart in their motors? I think these people have other engine issues and it's not the plug. Eg. A lot of people have been having problems with Denso Iridiums. I installed them about 5 months ago, have a tune and haven't had any issues whatsoever.
· Registered
Car is bone stock, plugs are from 03/2009 so Im running the stock Saabs. Dont know exactly which ones are they. I'm installing a 3"DP and 2.5 dual catback. Gonna be running BSR 3.
Ive also read alot on the forums about problems with Denso Iridiums, and almost everyone says dont run iridiums... I dont understand why.
I have checked the AC-Delco branded double platinums, they're 4 bucks each and have a 5 year warranty....
So Im lost, too much conflicting information out there
· Registered
I know they are copper.. ;) :cheesy:
Unless you want to waste the $$ on some NGKPFR7T-10G (one heatrange cooler than stock (NGKPFR6T-10G), not sure if they are even available. Have to swap them earlier than factory so you waste the lifetime/cost balance there.
· Registered
Discussion Starter · #11 ·
ok, cus everyone says double platinum, etc.
Thanks for the info.
· Registered
My plugs were gone @ 50K stock, cracked in half.
· Registered
I run NGK BCPR7Es @1.0mm in all the tuned SS we have around here.
Nick, thanks for the information on the phone today. I called in regards to the Nordic stage 2 tune and the issues I was having. You suggested the BCPR7ES plugs, and I just wanted to double check that they do fit a 2004 9-3 Arc. Most websites list it for the older '98-'02 9-3 models. I can't find it locally, so before I order online I'd just like to double check.
Thanks!
· Registered
· Registered
I found these at my local store, they wanted me to buy some cheap pair saying iw as spending too much money on plugs, either way i ordered them as they have none in stock unfortunately. After reading up on my receipt they are only .4mm gap for stock. I do not have any type of tune right now so I was wondering if this would work or if i should by those new wire gap tools to change them over to 1mm
· Registered
seriously. :cry:
http://www.genuinesaab.com/psi/files/sparkplugsdi.htm ;) Now go swap them and :cheesy:
Local parts store should have them maybe not pre gapped (the -11 suffix) Dealer will have them too. Save you shipping. Just order by part number.
Got the new BCPR7ES in and gapped at .8mm. Took a quick spin afterwards, still feels the same. I don't have enough experience to know if it takes any length of time to notice a difference or if it should be right away.
If it should be right away, I'll have to look into other things to find the solution.
1 - 18 of 18 Posts
