1 mm is about .040" and 1.1 mm is about .044", so you are talking about a difference of .004". When plugs fire, a little of the center electrode wears away with each spark. Because of this, over time the gap of the plug will increase slightly. As the gap increases, the spark needs to be at a slightly higher voltager to jump the gap. This makes the coil (either a seperate coil or coil pack) work harder. The harder the coil(s) work, the sooner they will fail. With turbo cars, the higher the boost, the easier it is for the boost to cause a misfire with wider gaps. So, is .004" going to make a difference? Probably not under most normal conditions, but you do want to get it right, and even a little on the low side is better. Auto parts store in the US sell these round keychain spark plug tools for around $1.00. You just fit it into the gap and rotate it until it's snug and read the guage. You can open the gap with it, or tap the center electrode to close the gap. Plugs with multiple center electrodes or surface gap plugs cannot be adjusted. Don't trust "out of the box" or factory settings unless the threaded end of the plug has the round cardboard protector on it... Ron
