Yes. I generally use 15 ft lbs but Saab know better lol and the crush washer must be precrushed hence the tighten/loosen/tighten
FYI GM specify in their workshop manuals for LK9 LSJ LE5 LNF LHU engines which are all Gen 2-3 ecotec nee Saab 4 cylinder 16 valve DOHC engines found in 9-3 Ion Cobalt and Equinox 15 ft lbs. if spark plug has a crush washer it must be tightened loosened 3/4 turn Re torque. Of that there is zero doubt. 15-20 ft lbs ? Meh. If you choose 15 it will probably hit 17. 20 probably 22. Or more depending on who ( and how and what style tool )is using the torque wrench. Not enough to worry about here
