hey everyone
unfortunate event have brought me back for a second time. it started two days ago, i was driving to work. when idling at a red light my 2001 auto se with about 104,000 started vibrating moderately and emitting a sound similar to a serpentine belt slipping . ive had misfires on all four cylinders for a bit now and i was sure my DIC was about to fail. (procrastinated on buying a new one.)
at the next light "saabastian" shuts off and i cant restart it. after single handedly pushing it up and hill and into a 45 degree parallel park. i fetch two old dic's and give it a whirl with no sucess (not to mention my out of date battery)
so here i am this evening i located a brand new genuine saab DIC from CARQUEST for $301 and a new battery. so i start cranking and its not working i try on and off for about ten minutes until it finally turns over. (NEVER TAKES THIS MUCH EFFORT even with my old POS battery) within 5 seconds i can tell something is wrong, the vibrations return and then tear jerking sounds of metal grinding and cracking around arise . i turn it off and i smell my belt burt and just under the main belt drive there are pieces and shaving of metal on the ground.
and there is a noticable amount of oil starting just above the oil pan
i check insensitively and cannot find any components that aprear to have suffered damage nor did my belt seem burt or torn but there was light smoke coming off the main belt drive. i tested it again and can see its not an altenator lock up.
so i am left with water pump, power steering pump, A/C comp (of which i had replaced last year), or the main belt drive its self.
i had not codes but my oil light was on.
does anyone have any ideas? im soo afraid there are pieces of metal swimming around my oil pan that i dont have time to drop again.
i dont think i can out this thing in the shop again.
please check out this video i recorded of the sound (visual is basically usless)
note that start up had never sounded so "windy" or taken so long (NEW DIC AND BATTERY)
http://youtu.be/dVZY3kNe70E
