1 - 11 of 11 Posts
installed yesterday, ride is amazing, drop looks amazing (and was more than i had expected). and overall a very easy install (aside from a few issues like not being able to remove the back wheels due to corrosion, and trying to get the mounts off the rear shocks)
anyways here's some pics.
Installed:
before- ignore my rust :mad:
After:
Discussion Starter · #2 ·
will try and get a couple better daytime pics, just wanted to get something to look at :p
To the OP, align that thing ASAP or your tires will be toast alot sooner than stock. You'll need 2 camber bolt kits in the front. The rear can be adjusted with the stock eccentric bolts on the rear control arms.
Installed:
After:
What springs did you buy? I am getting Koni Yellows as well, thanks for the pics!
Looks good. When I had my Aero I had the Koni/ H&R setup with the MapTun strut bar and sub-frame brace from GS. Handled very well.
1 - 11 of 11 Posts
