Interesting! I must try that, having been through all the usual fixes you have tried.....
How should that work anyway?
cheers
B
cheers
B
Not all cars are equiped with this pipe and the plastic 'scoop' that goes with it. Saab introduced this as a modification during the life of the 900 which could also be retrofitted to earlier cars. Strangely I have seen cars built after the mod was produced without it.Smithy said:The air intake has a rubber drain tube, which exits into the drivers (uk) wheel arch. What tends to happen is the air intake collects leaves and over time this mush gets stuck in the drain tube.
In heavy rain the water pours into the air intake (and should be drained off by this pipe) and this slowly feels up with water, which passes the air filter and dribbles into the system.
