Saabs on the road in Southern California are becoming increasingly rare—I’m hoping for some help to avoid adding to the casualty list.
Car: 2001 9-5 base model 2.3, just shy of 200K miles.
Problem: smoking from the exhaust, smells like oil
Background: turbo blew apart, LOTS of oil dumped into exhaust. Replaced turbo and, while I was at it, new rings, valve seals, head gasket, miscellaneous parts. Cleaned all the oil out of the intercooler (and there was a lot).
Good news: car started right back up, and runs pretty well.
Bad news: it will not stop smoking (although much better than it was at first, not surprisingly).
For months now, I have been convinced that the oil in the exhaust was simply taking a LONG time to burn off. I drove it for hundreds of miles with no improvement. So I took the exhaust system off, from the cat back; no visible oil, so I concluded that no new oil was entering the exhaust, but there was still oil hiding in the mufflers. I successfully drained out some oil by upending the exhaust, then ran degreaser through it, then actually was able to stick a powerwasher nozzle into each end. (I figured worst that would happen if I damaged something I’d just bite the bullet and get a new muffler.) Upended again, stuck the blow side of the shopvac on it, and let it drain a long time. Fair amount of crud oozed out. I actually did this twice, having put the exhaust back on with no visible improvement, and the second time swished gas around inside. (Probably not the smartest thing to do, but I was careful and made sure to get rid of all fumes.) This time water flushed through came out very clean, so I was convinced I solved the problem. Put the exhaust back on. Again, no visible improvement after another couple hundred miles.
I really do not think it’s oil in the muffler anymore. I did a compression test: 150-155 in all four cylinders. Spark plugs looked pretty clean—no sign of oil. No smoke at startup. That’s one reason why I assumed oil in muffler—had to get hot before it started burning off. But after some experimentation, the smoke appears to happen only when the boost hits the yellow zone of the gauge.
Any ideas or suggestions gratefully accepted. I have smog inspection due and I would hate to have to give up my Saab. Thanks for any help.
