1 - 12 of 12 Posts
I see a lot mentioned about the smbc here, but I have no idea how it actually works. can anyone explain to me precisely how it manages to trick the t7 computer into letting boost rise faster, and into removing the boost limit in first and second?
it's just installed in series (hence the Smbc) with the boost pressure control unit so that the air signal sent to the computer is different from the actual boost. Basically the tighter you make the SMBC, the less boost the car think it's creating, so it increases it. This is how iunderstand it, if Im wrong please correct me.
so the t7 ups the boost to compensate, this i get... does the smbc eliminate the boost limit in low gears, or does it reduce it? i can totally understand the latter, the former confuses me.
it eliminates boost limit by making the car think the boost is lower than it actually is, so it compensates by increasing boost.
I thought the SMBC simply gave you instant peak boost in the lower gears but does not (when used safely and correctly), actually up the boost to above stock-maximum levels.
The SMBC reduces the boost limit in the lower gears. Being the SMBC setting on a T7 HAS to remain mild, it doesn't eliminate it but then again, how much can you actualy get in 1-2 gear being they are so short.
It is not used to raise peak boost. T7 won't allow for that.
okay, peak boost doesn't change, that's fine. do you know precisely how the SMBC reduces the boost limit on a T7 car? I can't envision an airflow situation where the computer can both 'believe' that there is less boost pressure than there really is, and still provide the right amount of fuel for the real amount of air going into the engine.
can anyone enlighten me? i'm looking for a really nitty-gritty explanation, if there is one!
The stock BCP bleeds off pressure in lower gears so not to have traction issues and gear box issues. It is not completely closed upon take off in first and second, it is continually open a bit. The SMBC will mask the pressure the BPC sees in first and second but the higher gears have higher pressures and therefore the BPC sees normal pressures. This is of course as long as the SMBC is used correctly with a mild setting.
now my ? is... what does a mbc+a do differently?
A manual boost controller can often (application specific) be added to a turbo charger installation to replace the OEM controller. This allows for:
· Higher than stock boost levels and power
· Faster boost response
Most MBCs are now ball-spring types, as these make the turbo spool up much faster than the older ‘bleeder’ type MBCs. The only downside of the ball-spring types is that they will always create boost pressure overshoots in an application where the turbo spools up very fast. As everyone wants fast boost response, so this is a common problem. And most OEM turbo setups are undersized which spool up very fast with a MBC.
Boost Pressure Overshoots:
· Often mis-named ‘boost spikes’
· An intrinsic property of all ball-spring type MBCs.
· Very common with typical OEM undersized turbo application.
Boost overshoots cause problems. They cause high torque transients that can send a clutch into slip in higher output applications. They also can trigger fuel cuts or other defensive measures in many ECUs. To avoid these, one has to reduce the boost setting. Thus one’s peak sustained boost is reduced by the magnitude of the pressure overshoot. This is a major loss of power. Why does all of this happen?
A ball-spring MBC does not flow until the boost pressure is very close to the boost pressure objective (that is the design objective). If the rate of boost increase is slow, there will be no problems. But if the rate of boost is fast, then the MBC needs to get the wastegate open very fast. But it is too late. The MBC simply cannot get the wastegate actuator flow pressurized and flow stroked fast enough, and there is a pressure overshoot. Lightweight balls and springs will not, can not, eliminate this problem!
A ball-spring MBC simply operates too late to regulate the boost pressure when the rate of boost response is fast. We all want fast boost response. The MBC+A overcomes this fundamental flaw in ball-spring MBCs by directly compensating for what the ball-spring MBC cannot do. The MBC+A applies a regulated pressure to the wastegate actuator as the boost pressure is increasing. This anticipates the actuation of the wastegate actuator (WGA). The anticipator pressure is adjusted to pre-pressurize the WGA. This regulated pressure is not enough to open the WGA. Now when the ball-spring MBC starts to flow, its flow can get to the business of stroking the WGA open immediately without delay.
Many MBC’s cannot be fed pressure from the intake manifold or TB, as this introduces a time delay that makes pressure overshoots much worse. These applications typically get pressure from the turbo compressor hose barb. Also, these applications suffer from boost pressures that droop drastically at high RPMs. The pressure is been regulated at the turbo compressor, not the intake manifold. The pressure at the manifold drops as the higher air flow rates creates pressure drops across the intercooler and piping. The MBC+A allows you to pressurize the MBC from the TB or intake manifold *. Boost pressure now only drops off when the turbo is up against its own flow limitations.
good information, great write up.
1 - 12 of 12 Posts
