Hi Guys,
A few weeks ago I started noticing a small amount of oil on my garage floor when my 04 93 wasn't parked in there. It was probably about a tablespoon amount after overnight being parked in the garage. Today I changed the oil on the car. Everything looked good around the sump drain plug and the gasket on the drain plug looked in good shape. When I was under the car I noticed a droplet of a brown liquid starting to form on what looked like a pipe that runs under the car (but I don't know what this pipe is). I snapped a quick picture attached here. My blue-gloved finger is pointing to where the droplet was forming and you can see drain plug right at the top, center of the picture.
Appreciate any advice.
W
IC piping. That thing is coated, lol. Look higher up.
It's part #5. Charge pipe off the turbo feeding the IC. I would check the turbo and see if it's leaking at the oil feed line.
