my 88 900t vert most of time it starts slow. New battery, all connections clean and tight, no drains on battery. Have tried with lights off, radio off etc and seems to just turn slow. Can this be a worn out starter issue.
Next thing I'd check is that the starter motor is getting the correct voltage from the battery in the first place, just 'cos the connections are tight doesn't mean it's ok ;)
That and make sure that by "all connections" you also mean the grounds.
