I installed a new slave cylinder and clutch kit in a 1985 900 Turbo. Just as pressure restored to the clutch system, the o-ring seal around the piston sleeve of the slave cylinder failed. I replaced the seal and again it failed however this time it was pushed out and in between the sleeve and slave cylinder body as if it was too small. A friend in a machine shop ordered the replacement seal and was 'certain' it was the OE size. This time around I am going to order an OE slave repair kit but, I want to know if perhaps I am doing something incorrectly that is causing the seals to fail.
