Hello All,
I changed my shifter cable in my 2007 9-3 sedan. It’s an automatic.Shifter in car worked to change gears but now it skips neutral and when I get to drive on the shifter it puts the car in neutral. I can’t put it in drive with shifter. I can manually put it into drive by moving the connector plate on the transmission to drive. When I manually put it into drive through the connector plate it will shift into neutral and up to reverse. But if I shift back down to drive it skips neutral again.i called a dealership and they said it may be a loose but on the connector. I took it all back off and tighten it as tight as I could and that didn’t help.
Any ideas?
