Got a new clutch master from Skandix to replace my leaking original, but am having a problem and wondering if anyone has any ideas.
The Skandix unit arrived with a solid plastic cover, with no way to attach the original's cap which has an outlet for the hose going to the remote fluid reservoir (the one right next to the brake fluid reservoir tucked up under the hood scoop). The original unit has threads inside the clutch master's reservoir to accept the original cap and hose, the Skandix unit does not. The threads for the plastic cap are on the outside of the new cylinder.
Given the crazy location of the Sonett's master cylinder, the remote fluid reservoir is a must. Any ideas on how I might be able get some sort of cap solution that would allow for the remote reservoir? Skandix was no help - they basically said that the cylinder being listed for the 95, 96, and Sonett is wrong - it really only works as a direct replacement for the 95 and 96 and that they would change the info on their website.
Thanks for any ideas,
Kevin
Kevin
