Hi
I'm finding a lot of mixed results when attempting to look up a diagram for the PCV system for the B204L ('99 9-3). Is it simply the two hoses that go from the nipple on the camshaft cover - one goes to a check valve and then to the throttle body via a 4 mm ID hose, and then the other goes off to the left and down to the front of the car, in to the air intake pipe/hose whatever
Is there no breather pipes that go to the back of the throttle body? And one that goes from the throttle body to the oil pan?
Thanks for your help
