Basre said:
Although in Fairness there is NO genuine advantage over OEM.. besides pretty colours
Longevity maybe?
For the small vacuum lines which are the main ones to replace, I think the rubber hoses are 3mm ID, but for silicone you can use 2mm or 3mm ID. I think 2mm is better as it's a tighter fit and as Basre says, silicone hoses are more prone to popping off or leaking unless tied.
Agreed though that the best and surest way is to measure yourself :cheesy:
Be careful with the hose to the MAP sensor from the inlet manifold - I don't advise replacing this unless it's rotten, as its characteristics are critical to the correct running of the engine. If you do replace it, I think it's safest to get a genuine item.
