So this appeared on me today. I have no idea why. I have no apparent signs of break-in or anything like that. And all functions, alarm, door lock, fob, etc. seem to be in prefect working order. So this is odd... I had it do it on two seperate start-ups. I will continue to do extensive testing to make sure everything is seeming to work fine.
Any ideas what could be wrong? Things to check? Similar experiences? I could just go to the dealer, but I'd rather not if I can fix it myself. Or maybe it will go away and then I won't have to worry. Thanks!
The batteries inside the alarm unit. IN the car are going bad. There is a fix for them but requires desoldering the batteries off the alarm unit. Not a big deal but requires some work. Other alternative is to replace the alarm unit...$:eek: 250
thanks guys. I'll probably clear it out (hold it down til it beeps twice, right?) and see if it keeps doing it. Otherwise I'll probably have the dealer fix it.
Turns out it was the batteries. Since the car is certified they are also going to replace the siren. I guess this is a similar compenent or something, so it's easy to do both at once.
