I keep getting an error message saying "brake light failer". but my brake lights are working fine. is the Sid going bad? or should i just not worry about it'
Your SID is not going bad, you probably just have a bad connection on one of the bulb holders. Take out all the bulbs (4 in total) and clean up the connections and the metal contacts on the holders.
If you have a sedan pay extra special attention to the high-mount brake light. Sometimes the contacts get dirty or one bulb will flake out in there.
I had the same warning the other day and it ended up being the high mounted center brake light. One of the bulbs in the cluster was out.
