1 - 10 of 10 Posts
All,
My '99 9-3 2.0 convertible is showing a check oil level warning on the SID on every start. I dismiss it and it stays off until next start.
The level looks fine on the very approximate dipstick. No low oil pressure warning.
I found the below:
https://www.saabcentral.com/threads/sid-check-oil-level.57029/#post-507130
Apparently only the V6s have a sensor for oil level. I looked up the online WIS: https://saabwisonline.com and don't see an oil sensor, do see coolant level sensor.
Any ideas?
thanks
Breck
VIN YS3DD75N9X7022821
B204L engine
T5 engine
190k miles
Are you sure it says to check oil level? There is no oil level sensor in the car, so it's tough to understand how it could get such a message.
That's odd. If it's always been that way, I would suspect a transplant from another car without the requisite reprogramming. I think the NG900SEV6 had a level sensor.
It is a recent phenomenon, had the car for more than a year before it came on. The oil was actually low first time it came on. Coincidence?
Breck
Update:
So I did standard maintenance which entailed swapping spark plugs and air filter, no oil change, and around the 2nd time I started the message went away. I am pretty sure it existed the first time I started after swapping plugs. I also tested my spare DIC which I swapped back to the original one. The message has stayed away.
So perhaps DIC fault or plug swap made the difference.
Is there a "swap plugs" or DIC busted SID message that might have gotten confused?
It could be a coincidence but thought I would share.
Breck
Your SID somehow lost its coding and has defaulted to a V6 coding. There is no level sensor on any T5 car except for early T5 9000's. Don't worry, the SID is just losing its mind.
Tom: Do you know much about this sensor? Something that could be retrofitted to later models perhaps, even if it wasn't tied to the SID? Maybe a 9000 oil pan would bee needed or a mod to the pan?
I do not, but most information goes from ECU to then SID. That being said, V6's run a rendition of Motronic (I think?) that is different than any other Saab from those years. On the other hand some T8 9-3's have oil level sensors, and some don't. I've coded different year ECU's from T8 and not had a problem with the level sender. So I guess maybe!
1 - 10 of 10 Posts
