1 - 10 of 10 Posts
sick SID FIXED
well yesturday i managed to naff up my SID completely :roll: i had a few dead pixels so i thought i would fix it the way i did 18 months ago, by using a ball point pen and scribing across the ribbon to re attatch it to the curcuit bourd, unfortunatly i used a ball point pen with too small a ball and i just cut the ribbon right off, so instead of having a few dead pixels i now have a very blank screan :evil:
out of the darkness comes light :cheesy: :cheesy: after naffing up the SID i set about finding another one to replace it, well i found one, a breakers yard advertising on ebay had a 9-3 so i called them and bought one from them for £35 +p&p, this i couldnt beleive but ordered it any way :roll: not knowing what was going to turn up, when it arived today i opened it with intrepidation only to find ..................................SID2, yep not only did i find a SID for £35 it is a SID2 too :lol: how cool is that :cool: :cool:
Are the SID2 and SID3 interchangeable? My car has a SID3, but I hardly use the extra functions. It would make it easier to find a used one.
not sure about the 900 but all the sid2 functions work in my 9-3 (9-3 sid 2 is equivalent to sid3 in the 900)
My sid id also dieing. How easy is it to remove? Whats the ball point pent trick you mentioned? Whats the difference between SiD 1, 2 and 3? I hane a 1999 9-3s whats this likely to have?
Thanks.
Thanks.
the 900 has sid 1,2,3, sid 1 is just temp and radio display sid 2 is the same as 9-3 sid 1 and sid 3 is the same as 9-3 sid 2. my pixels were dieing so i took sid apart and where the display bourd is connected to the circuit bourd by a ribbon, this ribbon comes loose on the circuit bourd so i drew a line with a bic ball point pen accross the joint, this worked for 18 months but the second time i tried i used a ball point pen that had a very fine tip and it cut the ribbon off
Discussion Starter · #10 ·
arhh, i stand corrected :D
also sids from a 900 will not work in a 9-3, i know i tried :roll: as soon as i switched on the ign' my radiator fan came on and the display went wild :eek:
1 - 10 of 10 Posts
