Dear Saab enthusiasts,
Since I bought my classic saab 900 (1990) there has been a shudder in the drive line when I let go of the accelerator pedal. esspecialy when driving at low speeds the whole car shakes back and forth quite hard. This problem doesn't occcur when immediaty pressing in the clutchpedal. I have replaced the clutch, cv joints, right cv axle, front and passinger motor mount but the problem is still there. I'm really out of ideas and I need your guys help.
So if you have any idea where this problem lies, please leave a reply.
You're not too clear on the nature of this 'shudder'.
Do you feel it in the steering wheel or under your a**? High-frequency or low? Is there a noise associated with it? At any speed? Have you swapped tires?
Whole car shakes, it takes about 2 sec until the shocks absorb the shakings, after that the drive is perfect, at high speeds this problem isnt that noticable. The low speeds (5-30kph) is where the problem is the most annoying.
Worn inner drivers can make the whole car shake.
Search for that, see if it sounds like your problem.
