Hi,
I’m working on my 89 900 NA, this car does not have 1st, 2nd. I does have 3rd, 4th, and reverse. Maybe has 5th… either way I posted about this a while ago and let the car sit in the field. Now I’m back to the project and by the way, it shifted smooth in all gears until the problem developed instantly and the car was parked.
Previously I was told that it is most likely the rubber coupling between the trans and the fire wall. Well from what I inspected, I do not think the coupling is bad. This is a video I recorded where you can see the shaft on the firewall and the shaft on the trans move in unison.
second video is showing entirely the neutral range of motion. The shaft almost nearly doesn’t rotate at all. While the shift lever does not self center. This makes me think that there is a bushing that the lever pushes against and that bushing has broken. When I took the shifter lever out of its socket it visually looks fine. Though I might swap the one I have in my other car. Either way if you have advice after watching the videos that would be great! I’m concerned as the bushings are pretty much non existent online, though I do know a guy in Oregon that probably has some used parts.
youtube.com
