I picked up a 91 in pristine condish for dirt cheap from a gent who ran it with a wasted water pump. after rebuilding the head I have no fuel from the injectors, no voltage at the injectors. If I squirt some fuel in the intake she fires right up. Ive checked the grounds and have great continuity to b-.
What do I need to check?
Is the crank sensor connected and in working order?
where is the crank sensor?
The fuel rail has great fuel pressure. do the injectors run through any fuses or relays? where is the crank position sensor located? I know its somthing so simple and I cant wait to get my first saab going. Thanks for the help!
If you have an actual 91 900, meaning base model not a turbo, then it should be down by the crankpully/harmonic balancer, ie the bottom pully. It plugs in there and reads the crank, I don't know if you have to pull the pully to get to it or not, I don't think so but perhaps someone with more experiance than me can elaborate. Its pretty common for them to get eaten down there, was the car running when you got it?
I don't think your injectors will fire unless you are getting a crankshaft sensor signal though, they wouldn't know when to fire without that. Fuel pump will pressure up the bar however.
No, the guy I bought it from fried the water pump and ran it hot and shot the head. I had the head completely rebuilt. It is a no turbo 2.1. And I have had several people tell me it could be the crank sensor, I just dont know where it is. I do know how to test it and basically what Im looking for. It sounds like it might be visible from underneath.
