Hi everyone,
I've got an opportunity to buy a full set of tan leather seating that would fit in my 3-door 89 16V hatchback c900, and the seating is being removed from an 86 aero/spg. I don't believe the seating arrangement changed in c900's until 1990 or 1991 but just to be sure before I commit to anything, I'd like to find out the definitive answer!
Thanks if you can help out with this.
The same person also has a full 16V intercooler kit which I plan to buy for when I graft the turbo onto the 16V n/a engine in the coming weeks! :cool:
Craig.
912 fanatic said:
they changed in 1988 to the 4 bolt style
yep, they changed in 88 and in 91 i believe
not to say with a welder or a little imagination this small problem couldn't be fixed fairly easy ;)
I have an 88 (Built December 88 If I remember). Front passanger seat is four bolts but drivers is only 2 which is the old style I think.
here's the 4-1-1 on this
the 86 SPG seats WILL fit your 88 3 door, as long as your 88 3 door does not have the passive (automatic belts).
generally speaking, c900 seats up to and including 1987 are all the same mounting systems. 88 and 89 4 doors are that same system, but 3 doors were a bit of a wildcard. then 1990 those mounts are back with that exact same mounting system. in 1991, the seats in all c900 models changed.
so... the question mark years. 88 and 89: 88 and 89 4 door c900 seats are compatible with the up to and including 1987 and 1990 styles.
but in 88 and 89, many US market c900 3 door models were fitted with automatic/passive belts. these 3 door cars' seats will not interchange. they had different seat frames and welded mounts.
So. If your car does NOT have those poorly designed mouse/passive belts, the 86 SPG seats will 100% fit.
