so the break booster will be good enough right?Well, it doesn't really matter that much. I just took on the charge air delivery pipe that runs across the motor and poured half into the throttle body and half into the gas... it'll smoke like crazy until it burns off.
Yeah the hose thats sucking in airshould be, just make sure you're pouring it into the intake manifold and not the brake vacuum lines![]()
I would use one of the vacuum lines that comes off of the vacuum fitting(#4) on the left side of the intake manifold. Use the top line as I believe the bottom line goes to the fuel pressure regulator. Using the brake booster line might be too big which could hydro lock the engine.
i have a bottle of this sitting in my trunk right now. im scared to death though. could somone post a picture of the hose i should be usuing. i would hate to hydrolock my motor...thanks in advance.
something other then whats posted in "post 6". that may as well be the rosetta stone for me. i would really appericate a true to life picture of which hose i should use lol.
