1 - 2 of 2 Posts
Hi, I know a few of you peeps have put scania truck badges on your bonnets instead of the saab one, I am considering this, just a question before i buy? Are they the same size, I have seen one that measures about 3" long, could this work?
Thanks Adam​
G
Hi Adam, they are not a direct swop. On the rear of the badge is 2 plastic rods that should push into corresponing holes on the car. However these do not line up with the 9-5's. What you will need to do is remove the two plastic rods (a sharp knife, hack saw, dremmel will work) Then you will need to stick the badge in place. I used rubber silicon on mine and they dont budge. :cheesy:
Find the badges on eBay, usually around £10 :cheesy:
Finn :)
1 - 2 of 2 Posts
