Had my mechanic install a Sachs ZF clutch kit with new LuK DMF and FTE slave. Also Redline MT85 fluid change. I'm getting a clacking sound while in neutral. If I press the clutch in, the noise goes away. If I push the clutch in and release it very slowly, the noise also goes away. The clutch grabs very low (basically right off the ground) so also wondering if bleeding would fix it. I really need your guys advice on what to do about this. I'm not sure if this is normal for the Sachs clutch or if I should bring it back the mechanic and tell him to get it right, or bring it to another mechanic altogether. Not sure where to go from here honestly.
Sent from my LM-V405 using Tapatalk
