1 - 2 of 2 Posts
I have a 1999 Saab 95 V6. It has full dealer history and has had no problems. Recently it started holding back slightly at high speed as if it was missing slightly. Then one day i lost most of the power, got CHECK ENGINE, and had a little smoke/steam from behind the main block( rear). Took it to be looked at and they cant find out what the problem is. Not plugs, coils,air flow meter etc any ideas please
If you have got a Check Engine Light and the cause isn't obvious then you MUST go to either a main dealer or a SAAB specialist who has a TECH2.
The problem causing the C.E.L. will be saved in the ECU and only the TECH2 can give a detail'd report.
1 - 2 of 2 Posts
