The lines are accessible with the carpet and door sill removed.
In some of the pictures half way down you can see them. They come through the firewall on the left side, run down the door sill and then down to the floor.
They end up exiting through the floor above the rear axle.
That is an 88, but I assume the earlier system on an 86 is very similar.
http://www.saabcentral.com/forums/showthread.php?t=211326&page=3
Chances are good you aren't going to like what you find under there if you already have a rust hole and likely a rusted out brakeline.
